CVS, configure bootstrap
emu at ecubics.com
emu at ecubics.com
Fri Jun 10 11:10:54 UTC 2005
Hi all, so just installed autocon & automake, checked out CVS, but it is still missing the "Makefile.in" file ...
Is this OK ? Probably not, as it can't compile RTEMS after that :(
------------------ cut -------------------------------
$ ./bootstrap
./c
configure.ac: installing `../install-sh'
configure.ac: installing `../missing'
configure.ac:10: installing `../config.guess'
configure.ac:10: installing `../config.sub'
./c/src/ada-tests
' is already registered with AC_CONFIG_FILES.
autoconf/status.m4:848: AC_CONFIG_FILES is expanded from...
configure.ac:80: the top level
autom4te: /usr/bin/m4 failed with exit status: 1
aclocal: autom4te failed with exit status: 1
automake: autoconf failed with exit status: 1
grep: Makefile.in: No such file or directory
./c/src
configure.ac:267: the top level
./c/src/lib/libbsp/arm/armulator
Makefile.am: installing `../../../../../../compile'
Makefile.am: installing `../../../../../../depcomp'
./c/src/lib/libbsp/arm/csb336
./c/src/lib/libbsp/arm/csb337
./c/src/lib/libbsp/arm/edb7312
./c/src/lib/libbsp/arm/gp32
./c/src/lib/libbsp/bare
./c/src/lib/libbsp/c4x/c4xsim
./c/src/lib/libbsp/c4x/c4xsim/tools
./c/src/lib/libbsp/h8300
./c/src/lib/libbsp/h8300/h8sim
./c/src/lib/libbsp/i386
./c/src/lib/libbsp/i386/i386ex
./c/src/lib/libbsp/i386/pc386
./c/src/lib/libbsp/i386/pc386/tools
./c/src/lib/libbsp/i386/ts_386ex
./c/src/lib/libbsp/i386/ts_386ex/tools
./c/src/lib/libbsp/m68k
