CVS, configure bootstrap
emanuel stiebler emu at ecubics.com
Sat Jun 11 10:10:48 UTC 2005
Joel Sherrill <joel at OARcorp.com> wrote:
> emu at ecubics.com wrote:
>> Hi all, so just installed autocon & automake, checked out CVS, but it
>> is still missing the "Makefile.in" file ...
>> Is this OK ? Probably not, as it can't compile RTEMS after that :(
> Did you install the RTEMS auto* RPMs and use them?
> This is likely a wrong auto* version issue.  You have probably
> also generated a lot of unnecessary files.
I can't get the ones from rtems.com. Something wrong with the access
permissions ?
-------------------------- cut ---------------------------
Forbidden
You don't have permission to access
/ftp/pub/rtems/linux/redhat/7.3/i386/rpms/rtems-4.7/rtems-4.7-apt-conf-0.0-0/SOURCES/rtems-apt-conf-0.0.tar.bz2
on this server.
Additionally, a 403 Forbidden error was encountered while trying to use
an ErrorDocument to handle the request.
Forbidden
/ftp/pub/rtems/linux/redhat/7.3/i386/rpms/rtems-4.7/rtems-4.7-automake-rtems-1.9.5-2/SOURCES/automake-1.9.5.tar.bz2
on this server.
