MVME5500 status, and on to PMC interrupts
Kate Feng
feng1 at bnl.gov
Tue Mar 1 11:36:21 UTC 2005
Hi Peter,
Not sure if you got this E-mail yesterday. Here is again. See below.
Peter Dufault wrote:
> On Feb 28, 2005, at 1:04 PM, Kate Feng wrote:
> > it seems that the IRQ of the 2nd PMC730 returns as a VME
> > interrupt 3. My understanding is that the PMCspan card is
> > a VME module featuring the DEC21150 PCI-to-PCI interface
> > bridge. You do not need to write a newdriver for the bridge to
> > search for the PMC module. However, I think you need to program
> > the PMCspan VME module corrctly to access the returned address
> > space.
> It isn't really a VME module though it takes up a VME slot. It hooks
> up to the PCI expansion connector on the MVME5500. You can also add a
> "PMCSPAN-010" for two more PMC slots. I think it is only picking up
> power from the VME and using the P2 connectors for user I/O.
> If you look at table 2-1 of the MVME5500 Programming Manual you'll see
> that the PMC expansion returns "PCI AD Line AD20" and INTA# through
> INTD# of 12, 13, 14, 15, that second set matches the VME INTA# through
> INTD# assignments, but the VME uses "PCI AD LINE AD16". Maybe you
> understand this, I don't yet. I'm assuming there is some offset to
> these interrupt numbers based on how they feed into the GT64260 that
> get you from 0x08 to 0x48.
> Also, if you look at the log I sent you and at the mvme5500 pci.c, I
> don't think the code is setting up that DEC21150 bus properly. I don't
> see any iteration over that bus once it is discovered, similar to the
> way the code iterates over new busses in the "shared/pci" directory, so
> I don't think things are properly enabled for the boards on the other
> side of the bridge. By brute force looking at higher PCI bus numbers I
> am seeing it after startup but I don't think it is setup and thus the
> memory problem when I try to look at registers. Note that access to
> the first PMC730 and the PMC341 are logged during startup, but the
> second PMC730 never is, the first you see it is after my code is
> running.
Maybe it will help if you can send me your code so that I can
understand what went wrong. I do not have a PMCSPAN module.
However, I will read the datasheet you sent me.
In your log :
> pmc730_1 at 0x01FFED68: 0/2/2/0 base address B4000000 intr 0E.
For the 0/2/2/0, I am not sure what the first 0/ means ?
Cheers,
Kate
