Multilib swamp (was: Re: PowerPC architecture: Which processors have 8 BAT registers?)
    Peter Dufault
    dufault at hda.com
    Wed Mar  2 00:48:30 UTC 2005
On Mar 1, 2005, at 3:56 PM, Till Straumann wrote:
> Peter Dufault wrote:
>> I want to add the DBAT{4,5,6,7}{U,L} registers and asm access
>> routines for the additional BAT registers present on the MPC7455. I
>> plan to define a feature test such as PPC_HAS_8_BATS to
>> conditionalize it on to rtems/score/powerpc.h.
> PLEASE don't - this will get us into the multilib swamp again.
> Consider a run-time check for CPU version that generates an error
> if the CPU executing the code doesn't support the additional BATs.
> AFAIK, the init-code testing the CPU version would also have to
> enable the additional bats, wouldn't it?
(uh-oh, back in the multilib swamp)
I thought about this some more while researching enabling BATs, and I
have only one complaint about run-time only code.  I said something
earlier about code size, but I don't really care that much about code
size except very rarely, and then I wind up tearing the source apart
anyway to squeeze things in a straitjacket.  The additional size to
handle processor types from embedded to full-blown on PPC is minimal in
an application that pulls in referenced code at link time.  But I am
concerned that leaving obvious failures to run-time (that is,
potentially referencing a non-existent processor capability) is
equivalent to a big complaint that I have with using most interpreted
languages in critical systems - leaving blatant error detection until
run time, especially given the vaguearies of run-time code path
determination and when you might finally find a run-time error.
So, I see where you're coming from, but can you help address the above
concern at the same time?
Peter
Peter Dufault
HD Associates, Inc.
