Multilib swamp
Till Straumann strauman at slac.stanford.edu
Wed Mar 2 01:30:16 UTC 2005
Peter Dufault wrote:
>>> I want to add the DBAT{4,5,6,7}{U,L} registers and asm access
>>> routines for the additional BAT registers present on the MPC7455. I
>>> plan to define a feature test such as PPC_HAS_8_BATS to
>>> conditionalize it on to rtems/score/powerpc.h.
>> PLEASE don't - this will get us into the multilib swamp again.
>> Consider a run-time check for CPU version that generates an error
>> if the CPU executing the code doesn't support the additional BATs.
>> AFAIK, the init-code testing the CPU version would also have to
>> enable the additional bats, wouldn't it?
> (uh-oh, back in the multilib swamp)
> I thought about this some more while researching enabling BATs, and I
> have only one complaint about run-time only code.  I said something
> earlier about code size, but I don't really care that much about code
> size except very rarely, and then I wind up tearing the source apart
> anyway to squeeze things in a straitjacket.  The additional size to
> handle processor types from embedded to full-blown on PPC is minimal
> in an application that pulls in referenced code at link time.  But I
> am concerned that leaving obvious failures to run-time (that is,
> potentially referencing a non-existent processor capability) is
> equivalent to a big complaint that I have with using most interpreted
> languages in critical systems - leaving blatant error detection until
> run time, especially given the vaguearies of run-time code path
> determination and when you might finally find a run-time error.
> So, I see where you're coming from, but can you help address the above
> concern at the same time?
Hmm - it's still a little different from syntax checking [interpreted
vs. compiled]. You still
could end up compiling for the wrong variant - an error which you would
detect only
at run-time. OTOH, the run-time checking also allows application code to
behave differently
[without having to propagate #ifdef], e.g.,
if ( set_dbat(8,xxx) ) {
   /* use another method, complain or disable feature on this platform */
vs.
#ifdef __xxx__
 set_dbat(8,xxx);
#else
 use_other_method();
#endif
I would argue that whereas conditional compilation reduces the
'vaguearies of run-time code
path determination' it shifts this problem simply to compile-time [many
possibly erroneous
#ifdef combinations are never really tested or even seen by the compiler
- hence the fact
that the compiler/linker doesn't detect an error on a given platform
doesn't prove that
your code is correct either]
Short answer: I guess I have no good answer...
Cheers
T.
> Peter
> Peter Dufault
> HD Associates, Inc.
