Multilib swamp
Peter Dufault dufault at hda.com
Wed Mar 2 02:07:21 UTC 2005
On Mar 1, 2005, at 8:30 PM, Till Straumann wrote:
>> So, I see where you're coming from, but can you help address the
>> above concern at the same time?
> Hmm - it's still a little different from syntax checking [interpreted
> vs. compiled]. You still
> could end up compiling for the wrong variant - an error which you
> would detect only
> at run-time.
Right, but that's why so much of quality control depends on process and
control of process.
> OTOH, the run-time checking also allows application code to behave
> differently
> [without having to propagate #ifdef], e.g.,
> if ( set_dbat(8,xxx) ) {
>   /* use another method, complain or disable feature on this platform
> vs.
> #ifdef __xxx__
> set_dbat(8,xxx);
> #else
> use_other_method();
> #endif
> I would argue that whereas conditional compilation reduces the
> 'vaguearies of run-time code
> path determination' it shifts this problem simply to compile-time
> [many possibly erroneous
> #ifdef combinations are never really tested or even seen by the
> compiler - hence the fact
> that the compiler/linker doesn't detect an error on a given platform
> doesn't prove that
> your code is correct either
You've got a great example on your side here, though you didn't point
it out explicitly, "set_dbat(8" doesn't look any different than
"set_dbat(3" to the compiler, and depending on how I add DBAT8 that
won't be picked up at all.  But your discussion of #ifdef combinations
isn't valid in my opinion because if I'm concerned about testing a
given combination of pre-processor definitions then I can easily reduce
my testing to be against that specific case in a way that is much
easier than testing against run-time code that supports all cases.
> Short answer: I guess I have no good answer...
Me neither.
> Cheers
> T.
Peter Dufault
HD Associates, Inc.
