Solved - Problem with rtems-CVS-050130 build for ARM i.MX/MX1/csb336 board + GCC-3.4.3 BUG
Pavel Pisa
ppisa4lists at pikron.com
Fri Mar 4 00:24:11 UTC 2005
Hello all
On Tuesday 01 February 2005 20:17, Joel Sherrill <joel at OARcorp.com> wrote:
> Pavel Pisa wrote:
> > Hello All,
> > please, help me with next bellow described problem
> > with CVS RTEMS sources for i.MX/MX1/csb336 board.
> > Problems manifests by next error message
> > arm-rtems-gcc --pipe -B../../../../../../lib/
> > -B../../../../../../csb336/lib/ -specs bsp_specs -qrtems -isystem
> > ../../../../../../csb336/lib/include -DASM -mcpu=arm920
> > -mstructure-size-boundary=8 -O3 -c
> > ../../../../../../../../rtems/c/src/lib/libcpu/arm/mc9328mxl/../../../lib
> >bsp/arm/shared/irq/irq_asm.S arm-rtems-gcc --pipe -B../../../../../../lib/
> > -B../../../../../../csb336/lib/ -specs bsp_specs -qrtems -Wall
> > -mcpu=arm920 -mstructure-size-boundary=8 -O3 -o irq.rel -qnolinkcmds
> > -nostdlib -Wl,-r irq/irq_rel-irq.o irq/irq_rel-bsp_irq_init.o
> > ../../../libbsp/arm/shared/irq/irq_rel-irq_init.o irq/bsp_irq_asm.o
> > ../../../libbsp/arm/shared/irq/irq_asm.o arm-rtems-gcc:
> > irq/bsp_irq_asm.o: No such file or directory
> > arm-rtems-gcc: ../../../libbsp/arm/shared/irq/irq_asm.o: No such file or
> > directory gmake[6]: *** [irq.rel] Error 1
> > gmake[6]: Leaving directory
> > `/mnt/hda8/usr/src/rtems/arm-rtems/arm-rtems/c/csb336/lib/libcpu/arm/mc93
> >28mxl' gmake[5]: *** [all-recursive] Error 1
Thanks for fast reply. I didnot want to pollute list with fuzzy questions,
but I have not solved that from reply information and because I have other
issues with new CVS RTEMS version, I have moved to the other tasks.
I have been returned onto right track by next notice:
On Thursday 03 March 2005 15:41, Joel Sherrill <joel at OARcorp.com> wrote:
> Ralf Corsepius wrote:
> > You need automake-1.9 with the patch Joel meanwhile should have made
> > available on ftp.rtems.org
> > Meanwhile you can d/l it from PR 546 in RTEMS Gnats
> hopefully grumble resolved. I think I have taken care of this
> one finally. There are now rtems-4.7 automake 1.9.5 RPMs
> on the ftp site. I am rebuilding the apt/yum indices
> right now.
The "automake-1.9.5-rtems-20050303.diff" and "automake-1.9.5.tar.bz2"
fully solved incorrect bootsrap problem. Thanks again.
> > http://gcc.gnu.org/bugzilla/show_bug.cgi?id=17810
> > Do you know, if it is present on GCC-4.0.0.
> Works there
> > The simplified test case can be obtained from GCC bugzilla.
> I added Ralf and myself plus checked it on 3.4.3 and 3.2.3.
> > Thanks for reply in advance
> No problem.
Thanks for bug and fix confirmation.
Best wishes
Pavel Pisa
PiKRON s.r.o. Phone: +420 2 96781671
Kankovskeho 1235 Phone/Fax: +420 2 84684676
182 00 Praha 8 WWW: http://www.pikron.com/
Czech Republic e-mail: ppisa4lists at pikron.com
