Sample Program Output Format
Mike Bertosh
mbertosh at motioncontrol.org
Tue Mar 1 16:00:00 UTC 2005
Alan,
I did use m68k-rtems-objcopy when I tried to convert it. It just gave me an unknown
file type error. I tried using a bunch of different file types, but none of them would
work. I also tried to read the file with readelf and m68k-rtems-objdump but neither
would read the file so i figure it's not an elf file. I also used the file command to try and
see what type of file it is, but it just said that it was a data file. Thanks for your reply.
Mike
On 1 Mar 2005 at 10:48, Alan Cudmore wrote:
> Mike,
> Did you try using m68k-rtems-objcopy?
> The file should be in elf format, and you should be able to convert it to
> an srecord file.
> I would use: m68k-rtems-objcopy -Osrec ticker.exe ticker.s3r
> If that does not work you can always try: m68k-rtems-nm ticker.exe just to
> see if the ticker.exe is in elf format.
> Alan
> On Tue, 1 Mar 2005, Mike Bertosh wrote:
> > Hi all,
> > I am trying to run the rtems ticker.exe sample program on a Avnet MCF5282 eval
> > board to check if the clock tick runs properly. I am trying to convert this file to an S-
> > record so I can flash it to the board. The problem that I am running into is that I can't
> > find what output format the ticker.exe file is. I am trying to use objcopy to convert it to
> > the S-record. Can some one tell me what format this file is or can anyone give any
> > suggestions on a better way to convert this to an S-record? I would greatly appreciate
> > any help with this problem. Thanks for your time.
> > Mike Bertosh
> > Motion Control Systems Inc.
> > New River VA
