PCI API
gregory.menke at gsfc.nasa.gov
Thu Mar 3 04:21:04 UTC 2005
I think you have arranged a solution that only you will use- one more
bsp-specific pci kludge instead of a proper unified api. Best of
luck.
Kate Feng writes:
> Conclusion :
> Done! Eveyone will be happy. Thanks to all for clearing the
> confusion. I will add :
> #define MaxPCIbridgePerBandwidth 8 /* Did not figure out a better name yet */
> to the bsp.h of mvme5500. Thus I can use the original PCI API.
> However, in your previous E-mail, you wrote :
> >That may be acceptable for one particular current hardware implementation, but is completely unacceptable for
> >general use.
> >Once you transition to PCI-X it is common to have one bus segment per connector so that you can run at the
> >maximum data rate (133M transfers/s, or 266M if you use the dual rate variant). PCI Express systems will have
> >similar issues, because that architecture is inherently point to point and relies on switches. The switches
> >create multiple bus segments and look to the software like multiple PCI-PCI bridges.
> >Some of the large servers I work on have 64 or more bus segments. Those systems typically run a general purpose
> >OS rather than a real time OS, but it seems unnecessarily limiting to design an API into the RTOS or even into
> > the BSP which is known to be far below the architectural limitations of the bus.
> Thus, you can tune your own value of the MaxPCIbridgePerBandwidth
> in your bsp.h.
> How does that sound ?
Please keep your modifications out of the shared components of the PPC
pci api is all I can say.
Gregm
