RTEMS loopback test
Ali Asgar Nasir aliasgar.nasir at patni.com
Fri Mar 11 04:13:51 UTC 2005
a program calls the internal error occured function when any of the managers
has not been included during the compiliation time of the code...do check
the MANAGERS line in the makefile u use to compile....this line should
contain all the managers which u use...eg io semaphore message etc.....
Regards
ali
----- Original Message -----
From: "Mike Bertosh" <mbertosh at motioncontrol.org>
To: <rtems-users at rtems.com>
Sent: Thursday, March 10, 2005 9:24 PM
Subject: RTEMS loopback test
> Hi all,
> I am trying to get the loopback test to work on my Avnet MCF5282 eval
board. I run
> the test and here is the output that it gives me:
> "Network" initializing!
> "Network" initialized!
> Try running client with no server present.
> Should fail with `connection refused'.
> Connect to server.
> Can't connect to server: Connection refused
> Client closing connection.
> Start server.
> Try running client with server present.
> Connect to server.
> Client task terminating.
> Using gdb I was able to figure out that the program halts in the
> internal_error_occurred function. I know that my clock tick is working and
I am using
> polled i/o for my console driver. Does anybody have any ideas on why the
internal
> error occurs? I'd appreciate any help. Thanks for your time.
> Mike Bertosh
> Motion Control Systems, Inc.
> New River, Va
> 540.731.0540
http://www.patni.com
World-Wide Partnerships. World-Class Solutions.
_____________________________________________________________________
This e-mail message may contain proprietary, confidential or legally
privileged information for the sole use of the person or entity to
whom this message was originally addressed. Any review, e-transmission
dissemination or other use of or taking of any action in reliance upon
this information by persons or entities other than the intended
recipient is prohibited. If you have received this e-mail in error
kindly delete  this e-mail from your records. If it appears that this
mail has been forwarded to you without proper authority, please notify
us immediately at netadmin at patni.com and delete this mail.
