Cygwin Documentation
Brian Rose
lists at brianrose.net
Mon Mar 14 16:11:18 UTC 2005
Camilo Alejandro Arboleda wrote:
> No, you need the link to build the compiler and the gnu toolset.
> Alfer installing the cross-compiler (make install) you'll need to add
> the binaries to the path editing /et/profile (if you use bash).
>> Thanks in advance..
The directory where my i386-rtems-as, i386-rtems-c++filt, etc are in the
path. Do I need to link one to cc? OR is it enough to have the exe's in the
path?
Note: I do not see a i386-rtems-cc.
This is what I have...
i386-rtems-addr2line
i386-rtems-ar
i386-rtems-as
i386-rtems-c++filt
i386-rtems-ld
i386-rtems-nm
i386-rtems-objcopy
i386-rtems-objdump
i386-rtems-ranlib
i386-rtems-readelf
i386-rtems-size
i386-rtems-strings
i386-rtems-strip
Is there anything missing?
Brian
