loopback sample problem
Grigori Khmyrov
Grigori_Khmyrov at uml.edu
Wed Mar 30 21:37:43 UTC 2005
Thanks everybody for pointing me to the right direction.
I found the errors in the loopback's source code.
There is result of comparing files init.c and INIT_ORIG.C
init.c is fixed one, INIT_ORIG.C is original one from the distribution
rtems-4.6.2/c/src/tests/samples/loopback/
May be somebody can submit changes to the new RTEMS distribution
because it scare when even simple examples don't work.
1. Strange printf parameters.
***** init.c
printf("Read %d from server: %s\n", i, cbuf);
***** INIT_ORIG.C
printf("Read %d from server: %.*s\n", i, i, cbuf);
2. Delete task after client done
***** init.c
printf("Client task terminating.\n");
rtems_task_delete(RTEMS_SELF);
***** INIT_ORIG.C
Let some time to server to run (Server has low priority compare to client)
***** init.c
spawnTask(serverTask, 150, 0);
rtems_task_wake_after(20); /* Simulate client delay */
***** INIT_ORIG.C
Let's make RTEMS better!!!
Grigori Khmyrov wrote:
> Hi all,
> I'm new user of RTEMS. I just installed it first time. I'm trying to
> run sample programs from
> /opt/build-rtems/i386-rtems/pc386/samples
> It seems to me that the loopback.exe program doesn't work properly on
> the target computer:
> HSB-657I
> VIA C3 Eden CPU (i386 compatible processor)
> Half-Size CPU Card
> With LCD, Ethernet, PC/104 &
> CompactFlash, USB
> I load the sample using network and GRUB utility.
> The loopback.exe output looks like:
> "Network" initializing!
> "Network" initialized!
> Try running client with no server present.
> Should fail with `connection refused'.
> Connect to server.
> Can't connect to server: Connection refused
> Client closing connection.
> Start server.
> Try running client with server present.
> Connect to server.
> That's it.
> I've tried loopback.exe from all BSP pc386, pc486, pc586, pc686, pck6.
> All of them give me the same output.
> Why is it? Any help appreciated.
> I compiled rtems with options
> /usr/local/src/rtems-4.6.2/configure --target=i386-rtems
> --disable-posix --disable-itron --enable-tests --prefix=/opt/rtems-4.6
> Thank you,
> Grigori
