Fit in MCF5282 internal memory
Etienne Fortin etienne.fortin at sensio.tv
Mon May 2 18:11:53 UTC 2005
Hi Kolja,
I started my development on the MCF5282lite with the same idea: to fit all
in 64 KB and memory. And I gave up. You have to make too much sacrifice on
functionalities just to be able to do it, and even there, I don'T think it's
feasible. Well, it may be, but it would be quite a challenge. And given the
price of SDRAM right now, I'm not sure it's that interesting.
If you still want to try, there's a checklist in the RTEMS documentation
that allows you to figure how much memory your system will take given the
modules and the functionalities you desire.
Etienne Fortin
-----Message d'origine-----
De : Waschk,Kolja [mailto:rtems at telos.de]
Envoyé : 2 mai, 2005 14:03
À : rtems-users at rtems.com
Objet : Fit in MCF5282 internal memory
Hi,
I'm quite new to RTEMS and just succeeded to run some examples from CVS on
two boards with Freescale MCF528X (on a COBRA5282 and a DNP/5280), using a
slightly modified uC5282 BSP started from dBUG.
The BSP does make use of the rather large DRAM (8..16 MByte) and uses the
internal 64 kByte SRAM in the 528X only for Ethernet buffers, as far as I
can see.
Is it feasible to try to run RTEMS with only 64 kByte SRAM, i.e. using only
the internal memory in the 528X? I'm planning various small applications,
e.g. Ethernet bridging via serial interface (with no requirement for large
buffers).
Sorry if this or a very similar question was on the list before; I wasn't
able to search in the archives: the search cgi just gives me a completely
empty page.
Thanks for any hints in advance!
Kolja
Mr. Kolja Waschk, waschk at telos - +49(40) 450173-0; Fax -99 telos EDV
Systementwicklung GmbH - Schlueterstrasse 16 - D-20146 Hamburg
