Bug in sem_timedwait()
Peter Dufault dufault at hda.com
Mon May 23 19:39:23 UTC 2005
There is a bug in the POSIX sem_timedwait() implementation.  The
struct timespec() is supposed to be an absolute timeout but it is
implemented as a relative timeout.  The same code that is in
condtimedwait() (or even better, extract that code to a single place)
needs to be put in there.
Also, sem_timedwait needs to obey the rule that the timeout need not
be valid if the semaphore can be locked immediately.  I didn't check
that.
I'll open a bug report.  I don't think bug reports are sent to the
list so I posted this as well.
Peter
