building rtems-cvs failed
Philippe Simons loki_666 at fastmail.fm
Mon May 9 17:06:37 UTC 2005
this is for gcc
../gcc-4.0.0/configure --target=arm-rtems --with-gnu-as --with-gnu-ld
--with-newlib --verbose --enable-threads --enable-languages="c,c++"
--prefix=/opt/rtems-4.7 --disable-multilib --disable-interwork
and this is for rtems
../rtems/configure --target=arm-rtems --disable-posix
--disable-networking --disable-cxx --disable-itron --disable-rdbg
--enable-rtemsbsp=gp32 --prefix=/opt/rtems-4.7
and here the full error
gmake[3]: Entering directory `/tmp/b-rtems/arm-rtems/c/gp32/librdbg'
rm -f
../../../../../rtems/c/src/librdbg/src/powerpc/new_exception_processing/remdeb.h;
( cd ../../../../../rtems/c/src/librdbg && \
rpcgen -h -DFRONTEND=\"powerpc/new_exception_processing/remdeb_f.x\" \
  -o src/powerpc/new_exception_processing/remdeb.h src/remdeb.x )
cpp: -B../../../lib/ -B../../../gp32/lib/: No such file or directory
rpcgen: C preprocessor failed with exit code 1
gmake[3]: ***
[../../../../../rtems/c/src/librdbg/src/powerpc/new_exception_processing/remdeb.h]
Error 1
gmake[3]: Leaving directory `/tmp/b-rtems/arm-rtems/c/gp32/librdbg'
Philippe
On Mon, 09 May 2005 10:27:24 -0500, "Joel Sherrill <joel at OARcorp.com>"
<joel.sherrill at OARcorp.com> said:
> Philippe Simons wrote:
> > Ok, I just tried to build RTEMS-CVS yesterday but whihout success...
> > I'm using autoconf-2.59.tar.bz2 with
> > autoconf-2.59-quoting-20040817-1.diff,
> > automake-1.9.5.tar.bz2 with automake-1.9.5-rtems-20050303.diff,
> > binutils-2.15.tar.bz2 with binutils-2.15-rtems-20040519.diff,
> > newlib-1.13.0.tar.gz with newlib-1.13.0-rtems-20050301.diff
> > and gcc-4.0.0.
> > the whole configured for target=arm-rtems
> > the rtems build process hangs, with some weird error from rpcgen when
> > building the rdbg directory (btw: which i dont want to use anyway)
> > I dont remember the exact error, but there was something about powerpc
> > exception api, which is really weird, since i'm build rtems for arm.
> > I even tried to configure rtems with --disable-rdbg, it doesnt change
> > anything.
> > Does anyone have a clue on this issue?
> Can you give the exact command line?  I will try to duplicate it.
> Jennifer has been trying to unify the "new exception" IRQ APIs on the
> x86, PowerPC, and ARM.  She might have broken something.
> FWIW Ralf and I are bouncing email back and forth and I hope binutils
> 2.16 and gcc 4.0 RPMs will be out shortly.
> --joel
