building rtems-cvs failed
Philippe Simons
loki_666 at fastmail.fm
Tue May 10 17:06:41 UTC 2005
On Tue, 10 May 2005 07:03:19 +0200, "Ralf Corsepius"
<ralf.corsepius at rtems.org> said:
> On Mon, 2005-05-09 at 12:41 -0500, Joel Sherrill wrote:
> > Philippe Simons wrote:
> > > this is for gcc
> > > ../gcc-4.0.0/configure --target=arm-rtems --with-gnu-as --with-gnu-ld
> > > --with-newlib --verbose --enable-threads --enable-languages="c,c++"
> > > --prefix=/opt/rtems-4.7 --disable-multilib --disable-interwork
> > > and this is for rtems
> > > ../rtems/configure --target=arm-rtems --disable-posix
> > > --disable-networking --disable-cxx --disable-itron --disable-rdbg
> > > --enable-rtemsbsp=gp32 --prefix=/opt/rtems-4.7
> > Ralf, is this some odd type of configure/Makefile bug that is only
> > manifested when some timestamps trick rpcgen into running?
> I guess so.
> > I can't duplicate it.
> Neither can I.
> ATM, I suspect this to be the result of several bugs interacting ...
> 1. He reports not to be using --enable-rpcgen. Without it, the rpcgen
> generated programs are not supposed to be regenerated.
> To be investigated, probably a bug in c/src/configure.ac.
> 2. The error message indicates "cpp" complaining on "-B" options as part
> of the call to rpcgen, despite the fact that rpcgen does not pass these
> options to rpcgen.
> This indicates the rpcgen Philippe is using is could be pulling these
> flags "from the air". The question is why and where (environment,
> Makefile, wrapper scripts?)
> The only place "-B's" are used inside of the Makefile is as part of "CC"
> and "CPP", which would indicate Philippe's rpcgen being sensitive to one
> or more of these environment variables.
> However, this would be non-documented behavior and also doesn't make
> sense, because rpcgen is supposed to be using nothing but /lib/cpp
> underneath.
> Philippe, which OS are you using? Do you have CPP or CC explicitly set
> in your environment? Do you have any GCC variable set in your
> environment? Do you use any wrapper scripts to GCC?
My box is a Gentoo 2005.0 running on amd64, here is my env
INFODIR=/usr/share/info
HOSTNAME=omega3000
SHELL=/bin/bash
TERM=xterm
ANT_HOME=/usr/share/ant-core
USER=root
PRELINK_PATH_MASK=/usr/lib/gstreamer-0.8
GDK_USE_XFT=1
PAGER=/usr/bin/less
CONFIG_PROTECT_MASK=/etc/gconf /etc/terminfo
XINITRC=/etc/X11/xinit/xinitrc
PATH=/opt/rtems-4.7/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/opt/bin:/usr/x86_64-pc-linux-gnu/gcc-bin/3.4.3:/opt/ati/bin:/opt/blackdown-jdk-1.4.2.01/bin:/opt/blackdown-jdk-1.4.2.01/jre/bin
INPUTRC=/etc/inputrc
PWD=/root
JAVA_HOME=/opt/blackdown-jdk-1.4.2.01
EDITOR=/bin/nano
JAVAC=/opt/blackdown-jdk-1.4.2.01/bin/javac
PS1=\[\033[01;31m\]\h \[\033[01;34m\]\W \$ \[\033[00m\]
JDK_HOME=/opt/blackdown-jdk-1.4.2.01
SHLVL=1
HOME=/root
LESS=-R
LOGNAME=root
CVS_RSH=ssh
GCC_SPECS=
CLASSPATH=.
LESSOPEN=|lesspipe.sh %s
INFOPATH=/usr/share/info:/usr/share/binutils-data/x86_64-pc-linux-gnu/2.15.92.0.2/info:/usr/share/gcc-data/x86_64-pc-linux-gnu/3.4.3/info
DISPLAY=:0.0
LADSPA_PATH=/usr/lib64/ladspa
OPENGL_PROFILE=ati
CONFIG_PROTECT=/usr/lib/X11/xkb
G_BROKEN_FILENAMES=1
XAUTHORITY=/root/.xauthRunSJa
_=/bin/env
what do you mean by a wrapper script?...
#which gcc return /usr/bin/gcc which is plain elf file.
I reconfigured rtems with --disable-rpcgen option, and now build fails
with
Making all in librdbg
gmake[3]: Entering directory `/tmp/b-rtems/arm-rtems/c/gp32/librdbg'
gmake[3]: *** No rule to make target
`src/powerpc/new_exception_processing/remdeb.h', needed by `all'. Stop.
> > > and here the full error
> > > rm -f
> > > ../../../../../rtems/c/src/librdbg/src/powerpc/new_exception_processing/remdeb.h;
> > > ( cd ../../../../../rtems/c/src/librdbg && \
> > > rpcgen -h -DFRONTEND=\"powerpc/new_exception_processing/remdeb_f.x\" \
> > > -o src/powerpc/new_exception_processing/remdeb.h src/remdeb.x )
> > > cpp: -B../../../lib/ -B../../../gp32/lib/: No such file or directory
> > > rpcgen: C preprocessor failed with exit code 1
> Ralf
