building rtems-cvs failed
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue May 10 18:08:10 UTC 2005
Philippe Simons wrote:
> On Tue, 10 May 2005 07:03:19 +0200, "Ralf Corsepius"
> <ralf.corsepius at rtems.org> said:
>>>>this is for gcc
>>>>../gcc-4.0.0/configure --target=arm-rtems --with-gnu-as --with-gnu-ld
>>>>--with-newlib --verbose --enable-threads --enable-languages="c,c++"
>>>>--prefix=/opt/rtems-4.7 --disable-multilib --disable-interwork
>>>>and this is for rtems
>>>>../rtems/configure --target=arm-rtems --disable-posix
>>>>--disable-networking --disable-cxx --disable-itron --disable-rdbg
>>>>--enable-rtemsbsp=gp32 --prefix=/opt/rtems-4.7
>>>Ralf, is this some odd type of configure/Makefile bug that is only
>>>manifested when some timestamps trick rpcgen into running?
>>I guess so.
>>>I can't duplicate it.
>>Neither can I.
>>ATM, I suspect this to be the result of several bugs interacting ...
>>1. He reports not to be using --enable-rpcgen. Without it, the rpcgen
>>generated programs are not supposed to be regenerated.
>>To be investigated, probably a bug in c/src/configure.ac.
>>2. The error message indicates "cpp" complaining on "-B" options as part
>>of the call to rpcgen, despite the fact that rpcgen does not pass these
>>options to rpcgen.
>>This indicates the rpcgen Philippe is using is could be pulling these
>>flags "from the air". The question is why and where (environment,
>>Makefile, wrapper scripts?)
>>The only place "-B's" are used inside of the Makefile is as part of "CC"
>>and "CPP", which would indicate Philippe's rpcgen being sensitive to one
>>or more of these environment variables.
>>However, this would be non-documented behavior and also doesn't make
>>sense, because rpcgen is supposed to be using nothing but /lib/cpp
>>underneath.
>>Philippe, which OS are you using? Do you have CPP or CC explicitly set
>>in your environment? Do you have any GCC variable set in your
>>environment? Do you use any wrapper scripts to GCC?
> My box is a Gentoo 2005.0 running on amd64, here is my env
> INFODIR=/usr/share/info
> HOSTNAME=omega3000
> SHELL=/bin/bash
> TERM=xterm
> ANT_HOME=/usr/share/ant-core
> USER=root
> PRELINK_PATH_MASK=/usr/lib/gstreamer-0.8
> GDK_USE_XFT=1
> PAGER=/usr/bin/less
> CONFIG_PROTECT_MASK=/etc/gconf /etc/terminfo
> XINITRC=/etc/X11/xinit/xinitrc
> PATH=/opt/rtems-4.7/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/opt/bin:/usr/x86_64-pc-linux-gnu/gcc-bin/3.4.3:/opt/ati/bin:/opt/blackdown-jdk-1.4.2.01/bin:/opt/blackdown-jdk-1.4.2.01/jre/bin
> INPUTRC=/etc/inputrc
> PWD=/root
> JAVA_HOME=/opt/blackdown-jdk-1.4.2.01
> EDITOR=/bin/nano
> JAVAC=/opt/blackdown-jdk-1.4.2.01/bin/javac
> PS1=\[\033[01;31m\]\h \[\033[01;34m\]\W \$ \[\033[00m\]
> JDK_HOME=/opt/blackdown-jdk-1.4.2.01
> SHLVL=1
> HOME=/root
> LESS=-R
> LOGNAME=root
> CVS_RSH=ssh
> GCC_SPECS=
> CLASSPATH=.
> LESSOPEN=|lesspipe.sh %s
> INFOPATH=/usr/share/info:/usr/share/binutils-data/x86_64-pc-linux-gnu/2.15.92.0.2/info:/usr/share/gcc-data/x86_64-pc-linux-gnu/3.4.3/info
> DISPLAY=:0.0
> LADSPA_PATH=/usr/lib64/ladspa
> OPENGL_PROFILE=ati
> CONFIG_PROTECT=/usr/lib/X11/xkb
> G_BROKEN_FILENAMES=1
> XAUTHORITY=/root/.xauthRunSJa
> _=/bin/env
> what do you mean by a wrapper script?...
> #which gcc return /usr/bin/gcc which is plain elf file.
> I reconfigured rtems with --disable-rpcgen option, and now build fails
> with
> Making all in librdbg
> gmake[3]: Entering directory `/tmp/b-rtems/arm-rtems/c/gp32/librdbg'
> gmake[3]: *** No rule to make target
> `src/powerpc/new_exception_processing/remdeb.h', needed by `all'.  Stop.
>>>>and here the full error
I tried sim-linking my arm-rtems4.7 tools to arm-rtems-XXX and
could not reproduce it.  I was hoping there might be a slightly off
wildcard in a script.  But it builds fine for me using your exact
configure line.
Obviously something else is confusing it.
>>>>rm -f
>>>>../../../../../rtems/c/src/librdbg/src/powerpc/new_exception_processing/remdeb.h;
>>>>( cd ../../../../../rtems/c/src/librdbg && \
>>>>rpcgen -h -DFRONTEND=\"powerpc/new_exception_processing/remdeb_f.x\" \
>>>>  -o src/powerpc/new_exception_processing/remdeb.h src/remdeb.x )
>>>>cpp: -B../../../lib/ -B../../../gp32/lib/: No such file or directory
>>>>rpcgen: C preprocessor failed with exit code 1
>>Ralf
