PCI caching question related to mvme5500
Peter Dufault
dufault at hda.com
Tue Nov 1 11:06:23 UTC 2005
I'm merging the local changes I have in mvme5500 into cvs and then
I'll submit them via the bug reporting mechanism. While doing this I
want to do things more properly. This has to do with accessing a PCI
card's memory through a cached region.
To get decent throughput on the PCI data acquisition card (Acromag
PMC341) I had to read it through a cached address. To do this I used
a BAT register to create a second mapping onto the PCI bus that was
cached. I did this by adding a fixed PCI1_MEM_CACHED address to
libbsp/powerpc/mvme5500/include/bsp.h, setting up a BAT register, and
accessing it through that.
Much later when porting to vxWorks and again having it slow I
realized that the board does not properly say that its memory is pre-
fetchable. After poking around I figured out how to hook it up to
vxWorks as if it had said it was cached.
So, two questions:
1. If the board properly said it was pre-fetchable would RTEMS have
accessed a different mapping so things would have worked through a
cached mapping? If so I'll change it to do that. If not, on to
question 2.
2. Is there a better way that my PCI1_MEM_CACHED hack that won't take
too much time to implement? I don't have the time to do much but I
can at least put comments in the code around any hacks I have to
leave in.
Peter
