PCI caching question related to mvme5500
Kate Feng
feng1 at bnl.gov
Tue Nov 1 12:38:29 UTC 2005
Peter Dufault wrote:
> I'm merging the local changes I have in mvme5500 into cvs and then
> I'll submit them via the bug reporting mechanism. While doing this I
> want to do things more properly. This has to do with accessing a PCI
> card's memory through a cached region.
> To get decent throughput on the PCI data acquisition card (Acromag
> PMC341) I had to read it through a cached address. To do this I used
> a BAT register to create a second mapping onto the PCI bus that was
> cached. I did this by adding a fixed PCI1_MEM_CACHED address to
> libbsp/powerpc/mvme5500/include/bsp.h, setting up a BAT register, and
> accessing it through that.
> Much later when porting to vxWorks and again having it slow I
> realized that the board does not properly say that its memory is pre-
> fetchable.
Who was slow ? RTEMS or vxWorks ?
> After poking around I figured out how to hook it up to
> vxWorks as if it had said it was cached.
> So, two questions:
> 1. If the board properly said it was pre-fetchable would RTEMS have
> accessed a different mapping so things would have worked through a
> cached mapping? If so I'll change it to do that. If not, on to
> question 2.
It seems to me one could do so.
> 2. Is there a better way that my PCI1_MEM_CACHED hack that won't take
> too much time to implement? I don't have the time to do much but I
> can at least put comments in the code around any hacks I have to
> leave in.
This sounds good. -- Kate
> Peter
