Cogent 637 board
Camilo Alejandro Arboleda
camilo.arboleda at spymac.com
Thu Nov 3 14:13:11 UTC 2005
Hello,
I'm trying to boot rtems from a cogent 637 board. This uses uMon as boot
loader. As far as i can see, the 337 BSP should work, but when i boot
hello.exe, it seems to do nothing.
I downloaded the hello.exe (uncompressed) using tftp, then i check using
"dm" (dump memory) command from umon, and it seem to be fine. This is my
first attempt with this board, so I'm not sure what to do to find the
problem.
Has anyone in the list worked with this board?
