Cogent 637 board
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Nov 10 14:19:00 UTC 2005
Camilo Alejandro Arboleda wrote:
> I tried with gcc 3.2.3, with the same result. Given that remote
> debugging uses ethernet in this board, what shoul I do to track down the
> error?
If Jay;'s board works and yours doesn't, then I am prone to blame the
board.  Are there multiple revisions of it?  ROM or jumper settings
which could be different?
-joel
>>> I'm using RTEMS 4.6.99.2. Network driver is loaded, but it seems to
>>> fail in the ISR.
>>> Linux ethernet driver works fine.
>>> I already said that, but I've never worked with ARM before, and I
>>> don't know what to look for.
>> What gcc version are you using?  There have been cases with gcc 4.0.x
>> where something got optimized better and no longer works.
