Cogent 637 board
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Nov 10 14:24:27 UTC 2005
Joel Sherrill <joel at OARcorp.com> wrote:
> Camilo Alejandro Arboleda wrote:
>> I tried with gcc 3.2.3, with the same result. Given that remote
>> debugging uses ethernet in this board, what shoul I do to track down
>> the error?
> If Jay;'s board works and yours doesn't, then I am prone to blame the
> board.  Are there multiple revisions of it?  ROM or jumper settings
> which could be different?
Yet another case where I should read the entire thread before replying.  :(
More than likely ARM memcpy changed from the 4.6 newlib to the current
1.13.  So this alignment issue is now a factor.  I haven't looked at
newlib yet but if the newlib ARM memcpy does not properly deal with
misaligned memory, I would consider it a bug in that code and not
something the driver shoudl deal with except as a potential performance
optimization.
--joel
> -joel
>>>> I'm using RTEMS 4.6.99.2. Network driver is loaded, but it seems to
>>>> fail in the ISR.
>>>> Linux ethernet driver works fine.
>>>> I already said that, but I've never worked with ARM before, and I
>>>> don't know what to look for.
>>> What gcc version are you using?  There have been cases with gcc 4.0.x
>>> where something got optimized better and no longer works.
