What Cygwin Modules needed?
Bogdan Vacaliuc bvacaliuc at ngit.com
Sat Nov 12 15:05:06 UTC 2005
Hello Wolfram,
I don't have the list you are looking for, but a good way to determine what a minimum system is to start with a chroot jail and
build-up the items you need.  An excellent reference is Dan Kegel's crosstool:
http://kegel.com/crosstool/
http://kegel.com/crosstool/current/doc/chroot-login-howto.html
Also note Chris John's work with MinGW (http://www.mingw.org/) and RTEMS.  I believe Chris builds under this environment.
Specifically for RTEMS and Cygwin, your goal would be to be able to configure/build RTEMS under a suitably configured jail.  You
would setup binaries you need in it, and continue adding pre-built packages until you could successfully build the entire system,
and any applications you desire.  The set of libraries and programs that you end up with are your minimum environment.
About a year ago there were some Cygwin build issues that I and others worked on; I used the jail to define a minimum environment
with which to explore the failure.  As it relates to your question, I laid out a minimum set of binaries required in the /bin of
such a jail to execture the configure script (see the p.s., about halfway down):
http://www.cygwin.com/ml/cygwin/2004-09/msg00570.html
However, this isn't enough to run the compiler/linker to build RTEMS.
Good Luck and Best Regards,
-bogdan
P.s.  Sorry I do not answer your question directly; I have not worked with the Cygwin build environment for quite some time, and the
file archives are tedious to access...
> -----Original Message-----
> From: Wolfram Wadepohl
> Sent: Tuesday, September 27, 2005 9:13 AM
> To: rtems-users
> Subject: What Cygwin Modules needed?
> Hello,
> has anybody a list of cgwin modules, which are necessary for
> the cygwin
> environment for RTEMS?
> We want to keep the Cygwin footprint as small as possible.
> Schöne Grüße aus Reutlingen
> Wolfram Wadepohl
> Forschung & Entwicklung
> E&K AUTOMATION
> Indumat GmbH & Co. KG
> Siemensstraße 3
> 72766 Reutlingen
> Deutschland
> Tel.  +49 7121 514-289
> Fax   +49 7121 514-299
> eMail W.Wadepohl at indumat.de
>        Wolfram.Wadepohl at ek-automation.com
> WWW   http://www.indumat.de
>        http://www.ek-automation.com
> Bitte senden Sie mir keine Word- oder PowerPoint- (tm
> Microsoft)  Anhänge.
> Senden Sie mir einfachen Text, HTML oder PDF.
> Siehe http://www.gnu.org/philosophy/no-word-attachments.de.html
