SkyEye and EDB7312
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Nov 22 00:06:12 UTC 2005
I think the SkyEye simulator must be closer to workign than I thought.
This page has Chinese instructions on running hello with the edb7312 bsp
and 4.6.2.  I tried this with the CVS head without luck.   I tried to
make the changes I could grok out of that page.
http://www.rtems.net/Documnet/rtems_serial/RTEMS%202%20tutorial/2.5_Skyeye.htm
The simulator is at www.skyeye.org and I would appreciate it very much
if someone (especially someone who can read Chinese) can help me get
this running.
This is the skyeye.conf I put together:
#skyeye.conf
#skyeye config file sample
cpu: arm720t
mach: ep7312
mem_bank: map=I,type=RW, addr=0x80000000, size=0x00010000
mem_bank: map=M, type=RW, addr=0xc0000000, size=0x1000000
log: logon=1, logfile=/tmp/sk1.log, start=2000000, end=3000000
Thanks.
