rtl8139 network card driver works (BSP i386)
Grigori Khmyrov grigori_khmyrov at uml.edu
Wed Nov 23 14:25:30 UTC 2005
I'd like to let know to RTEMS users that the driver, that Angelo
Fraietta gave to me, works.
BSP i386 (actually I use i486)
// Library:        LibNICS - RTEMS ethernet drivers.
// File:        libRTL8139C.c
// Description: Driver for Realtek 8139C(L) based cards.
// Author(s):    Bill Paul <wpaul at ctr.columbia.edu>.  All rights reserved.
//                 RTEMS version: TECMAV srl -
a.verardo at tecmav.fastwebnet.it
// L.M. Date:    07-Nov-2003 (01:33:25)
I start to use it about a 2 months ago. It works in real application and
transfer data at the rate ~1 MB/sec.
I did not put it in the RTEMS source but just compile it with my
application.
I never test the driver in proper/recommended way. I wander may be
somebody can add the driver
to the RTEMS tree.
Grigori
Angelo Fraietta wrote:
> Grigori Khmyrov wrote:
>> Dear RTEMS guru,
>> I saw a big discussion in 2002 about somebody wanted to write driver
>> for rtl8139 network card.
>> Is it any rtl8139 drivers available or is it a way to make the card
>> work?
> I was involved in part of the discussion in that I wanted one written.
> I have searched through my archives and there are two main threads.
> One says that the 8139 in NE2000 campatible, but there are some minor
> incompatibilities.
> Adriano Verardo gave a driver, but I have not tested it yet because I
> am flat out with other work right now. I have sent you this in another
> email. Maybe you can let us know how you go with it.
>> Thank you,
>> Grigori
