Problem compiling RTEMS for edb7312
Frédéric PRACA frederic.praca at freebsd-fr.org
Fri Nov 25 13:08:35 UTC 2005
Selon Ralf Corsepius <ralf.corsepius at rtems.org>:
> I am using nothing fancy:
> * gcc-4.0.1+ (A snapshot taken from gcc-4_0-branch sometime between
> 4.0.1 and 4.0.2)
> * binutils-2.16.1
> * newlib-CVS
Does this path apply ?
ftp://ftp.rtems.com/pub/rtems/linux/redhat/7.3/i386/rpms/rtems-4.6/SOURCES/newlib-1.13.0-rtems-20050810.diff
> * rtems-CVS HEAD as of today.
> All of them have local patches applied, but none of them should have any
> influence.
> RTEMS configuration:
> configure --target=arm-rtems4.7 --enable-maintainer-mode
> make RTEMS_BSP=<whatever>
Well, I think I'll use the standard way to use RTEMS instead of experimenting
the newest version of each tool ;-) I wonder why I kept stuck in trying exotic
things !
Sorry to disturb you all once again and thank you for help.
> Ralf
Fred
