rtl8139 network card driver works (BSP i386)
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Nov 25 14:54:01 UTC 2005
Angelo Fraietta wrote:
>> Grigori Khmyrov wrote:
>>> I'd like to let know to RTEMS users that the driver, that Angelo
>>> Fraietta gave to me, works.
>> Angelo.. are you going to submit this driver?
> I am glad to hear that the driver works.
> I have not even tested the driver here. It was given to me a while ago.
> If you have an example simple app that shows the driver working - maybe
> just echoing a UDP message-- that would be great. Then I can test it on
> the PC104 module I have here. I won't have time before Christmas to do
> any in depth
> If it works fine, then that means I will have have the secondary IDE and
> the ethernet issues resolved and I can demonstrate RTEMS using the PC104
> system I have. This would be a great milestone for this module.
The network demos are those simple applications.  There is "netdemo"
which can be pinged and telnet to.  Then you can move through some of
the others .. for stability and performance run ttcp.
