Cogent 637 board
Ed Sutter esutter at lucent.com
Thu Nov 3 17:04:40 UTC 2005
And, if you made that '-f EB', then it would auto-boot.
Ed
Camilo Alejandro Arboleda wrote:
> Thanks a lot, the '-f E' made the trick (I'll read the documentation
> more carefully next time)
> Ed Sutter wrote:
>> Camilo,
>> I haven't worked with RTEMS on this board however, I may be able to
>> help...
>> Assuming hello.exe is an ELF file, and you're transferring hello.exe
>> into TFS
>> on the board, then it should be flagged as elf.  TFS needs to know
>> what kind
>> of file it is.
>> In the nutshell, if you are using a tftp client on your host to
>> download to
>> the uMon's TFTP server, then the destination filename should be
>> "hello.exe,E".
>> The ",E" suffix is treated as a flag by uMon's tftp server and will
>> store the
>> file as hello.exe with the flag "E".  This simply tells TFS that the
>> file is
>> executable ELF so that it can load it appropriately.
>> If you're using uMon's tftp client, then specify the "-F hello.exe -f E"
>> options on the uMpn command line to invoke the same idea.
>> Then, with the file installed in TFS, you can simply type "hello.exe"
>> at the
>> uMon command line and it should run (assuming it was built properly of
>> course).
>> I'll gladly help more; however, note that there is a pretty useful (IMHO)
>> user's manual covering uMon at
>> http://www.microcross.com/html/micromonitor.html.
>> Ed Sutter
>> PS...
>> If you add a 'B' to the flags (i.e. "hello.exe,EB"), then hello.exe will
>> automatically boot after reset.
