Request Example App Reading/Writing Files on Floppy
Camilo Alejandro Arboleda camilo.arboleda at spymac.com
Fri Nov 18 19:36:06 UTC 2005
I have an old PC driver (somewhere). It only works with 1.44 MiB
floppies and is pre-blockdev, do you thik it fits your needs?
Joel Sherrill <joel at OARcorp.com> wrote:
> Hi,
> I would appreciate it greatly if someone could send me an example
> application for the pc386 BSP that mounts a floppy and accesses files
> on it.
> I am beginning to reimplement the ancient DOS based software
> that our scout troop uses for Pinewood Derby timing.  I would
> like to use RTEMS for timing accuracy and want to keep records
> on the floppy.
> Thanks.
