Request Example App Reading/Writing Files on Floppy
Thomas Doerfler (nt) Thomas.Doerfler at imd-systems.de
Fri Nov 18 19:52:08 UTC 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Camilo,
although floppy drives get a bit outdated, it would still be interesting
to support them in RTEMS. If you send me your driver code, I might try
to adapt it to the blkdev architecture.
wkr,
Thomas.
Camilo Alejandro Arboleda schrieb:
> I have an old PC driver (somewhere). It only works with 1.44 MiB
> floppies and is pre-blockdev, do you thik it fits your needs?
> Joel Sherrill <joel at OARcorp.com> wrote:
>> Hi,
>> I would appreciate it greatly if someone could send me an example
>> application for the pc386 BSP that mounts a floppy and accesses files
>> on it.
>> I am beginning to reimplement the ancient DOS based software
>> that our scout troop uses for Pinewood Derby timing.  I would
>> like to use RTEMS for timing accuracy and want to keep records
>> on the floppy.
>> Thanks.
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
     http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.5 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDfjDnwHyg4bDtfjQRAhDhAKCSJ8svR8fmeti+OGqCcnJwyXmSXQCdG+hb
IAzpbutS9xtJ0UEdFuPSkic=
=+/B0
-----END PGP SIGNATURE-----
