4.6.5 build error
Jerry Needell
jerry.needell at unh.edu
Fri Oct 7 12:24:01 UTC 2005
OK - here is my first attempt to build rtems-4.6.5 for the sparc. My
configuration file is:
#! /bin/sh
../rtems-4.6.5/configure --target=sparc-rtems --disable-posix
--disable-itron --enable-tcpip --enable-networking --disable-cxx
--enable-tests --enable-rtemsbsp="leon2 leon3 erc32"
--prefix=/home/needell/leon/rtems/install
The build fails with the following:
gmake[4]: Entering directory
`/home/needell/leon/rtems/build/b-rtems/sparc-rtems/c/leon2/exec/score'
Making all in .
gmake[5]: Entering directory
mkdir o-optimize
gcc32 --pipe -DHAVE_CONFIG_H -isystem ../../../../leon2/lib/include
-D__RTEMS_INSIDE__ -mcpu=cypress -msoft-float -O2 -g -Wall -ansi
-fasm -o o-optimize/apiext.o -c
../../../../../../rtems-4.6.5/c/src/../../cpukit/score/src/apiext.c
cc1: bad value (cypress) for -mcpu= switch
gmake[5]: *** [o-optimize/apiext.o] Error 1
gmake[5]: Leaving directory
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory
`/home/needell/leon/rtems/build/b-rtems/sparc-rtems/c/leon2/exec'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory
`/home/needell/leon/rtems/build/b-rtems/sparc-rtems/c/leon2'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
`/home/needell/leon/rtems/build/b-rtems/sparc-rtems/c'
make: *** [all-recursive] Error 1
Any suggestions? I am puzzlesd by why it is using my native compiler
here "gcc32" rather than the cross compiler.
thanks - Jerry
