RFC: Remove BSP_Configuration
    Joel Sherrill <joel@OARcorp.com>
    joel.sherrill at OARcorp.com
    Thu Oct 20 15:54:20 UTC 2005
Eric Norum wrote:
> Joel Sherrill wrote:
> On Oct 20, 2005, at 10:06 AM, gregory.menke at gsfc.nasa.gov
> <mailto:gregory.menke at gsfc.nasa.gov> wrote:
>> "Joel Sherrill <joel at OARcorp.com <mailto:joel at OARcorp.com>>"
>> <joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com>> writes:
>>> gregory.menke at gsfc.nasa.gov <mailto:gregory.menke at gsfc.nasa.gov> wrote:
>>>>> My proposal would be to:
>>>>> (1) Eliminate BSP_Configuration entirely.  Do not copy
>>>>>      the generated Configuration to BSP_Configuration and
>>>>>      modified Cofniguration as required in the BSP.
>>>> We have found BSP_Configuration to be useful at runtime, having a
>>>> well-defined struct to pull footprint info out of is nicer than defining
>>>> symbols in the linker script.
>>> You would still have the structure -- it would just be called
>>> Configuration.
> I agree with the proposal but in the interest of namespace pollution
> reduction could the name be changed to rtemsConfiguration or something
> like that?
I don't see why not.  Pretty much everything that looks in a
configuration table will change anyway in a minor way to really
implement this correctly.
I expect this will shrink executables a bit but I can't guess how much.
> Eric Norum <norume at aps.anl.gov <mailto:norume at aps.anl.gov>>
> Advanced Photon Source
> Argonne National Laboratory
> (630) 252-4793
