RTEMS - LEON - Doubt
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Mon Oct 24 16:51:42 UTC 2005
sashti srinivasan wrote:
> Hello,
>    I use rtems over leon-tsim.  I use the
> rtems_interrupt_catch directive as follows.
> rtems_isr MyISR(rtems_vector_number)
>    printf ("\n ISR called");
I don't know if your ISR is called or not.  But I do know that if it is
invoked and that printf is called, the system is supposed to get a fatal
error because you are not supposed to print from an ISR.
> rtems_isr_entry *abc;
> rtems_interrupt_catch(MyISR,0x18,abc);
> Prescalar, timer1-reload, timer1-control registers are
> set appropriately and timer1-counter register contents
> are changing.  But MyISR is not called.  Help Please
Did you look at how the clock tick driver works?
> With Humble Regards
> S Srinivasan
> __________________________________
> Yahoo! Mail - PC Magazine Editors' Choice 2005
> http://mail.yahoo.com
