mvme23xx broken on rtems-4.6.5
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Mon Oct 17 21:15:51 UTC 2005
Till Straumann wrote:
>>> Don't know all the details yet. Board just hangs during early
>>> boot (bsp_start() before any messages are printed).
>> What was the last 4.6 version you know worked?
> Probably 4.6.2. From 4.6.3 on through 4.6.5 probably only
> the mvme2100 works.
Grrr.. this is the price of not being able to test everything.
Between psim being overhauled and adding the mvme2100 BSP, a lot of code
that this BSP uses got touched.
> Patch filed as PR#837
OK.
Did we reach a resolution on the termios PR you filed?
Eric.. can you confirm that the mvme2100 still works?
--joel
> T.
>> The only PowerPC BSPs changes between 4.6.4 and 4.6.5 were yours
>> to the irq code to disable the FPU during ISRs and Thomas' modifications
>> to the mbx8xx which have NO impact on the motorola_powerpc BSPs.
>> What tools are you using?
>>> -- Till
>> --joel
joel at OARcorp.com On-Line Applications Research
