mvme23xx broken on rtems-4.6.5
Till Straumann
strauman at slac.stanford.edu
Mon Oct 17 21:33:28 UTC 2005
>>>> Don't know all the details yet. Board just hangs during early
>>>> boot (bsp_start() before any messages are printed).
>>> What was the last 4.6 version you know worked?
>> Probably 4.6.2. From 4.6.3 on through 4.6.5 probably only
>> the mvme2100 works.
> Grrr.. this is the price of not being able to test everything.
> Between psim being overhauled and adding the mvme2100 BSP, a lot of code
> that this BSP uses got touched.
BTW: I noticed a few #ifdef mvme2100
that I think could be removed...
>> Patch filed as PR#837
> OK.
> Did we reach a resolution on the termios PR you filed?
Not quite - it's easy to check for raw mode but I don't
know what to do if we're not in raw mode. Still -
it's better to at least handle raw mode correctly than
nothing - could handle this in raw mode and generate
an error otherwise - how's that?
T.
> Eric.. can you confirm that the mvme2100 still works?
> --joel
>> T.
>>> The only PowerPC BSPs changes between 4.6.4 and 4.6.5 were yours
>>> to the irq code to disable the FPU during ISRs and Thomas' modifications
>>> to the mbx8xx which have NO impact on the motorola_powerpc BSPs.
>>> What tools are you using?
>>>> -- Till
>>> --joel
