RFC: Remove BSP_Configuration
gregory.menke at gsfc.nasa.gov
Thu Oct 20 14:26:40 UTC 2005
"Joel Sherrill <joel at OARcorp.com>" <joel.sherrill at OARcorp.com> writes:
> Hi,
> While teaching the class last week, it occurred to me that an RTEMS
> application has 2 copies of the Configuration Table and a separate
> pointer to it in the executive proper. Maybe this can be simplified.
> So I want some feedback.
> Currently:
> + confdefs.h generated a structure named "Configuration"
> + shared BSP code copies that to BSP_Configuration
> + RTEMS proper does not know the variable name Configuration
> or BSP_Configuration, so it takes a pointer in as an
> argument to rtems_initialize_executive_early and saves
> that address in a global pointer variable.
> My proposal would be to:
> (1) Eliminate BSP_Configuration entirely. Do not copy
> the generated Configuration to BSP_Configuration and
> modified Cofniguration as required in the BSP.
We have found BSP_Configuration to be useful at runtime, having a
well-defined struct to pull footprint info out of is nicer than defining
symbols in the linker script.
We haven't had a use of CPU_Configuration however.
The copying stuff related to these structs does seem a little clumsy,
but maybe its required or at least useful for other reasons.
> (2) This is somewhat disjoint. Let RTEMS assume that the
> Configuration Table has a known variable name and that
> it is "Configuration". This will eliminate the global
> variable in RTEMS proper and might reduce some code.
Renaming the structs would be fine as far as we're concerned.
Gregm
