Getting C++ to work on ARM
Yanjun Luo
yanjun.luo at gmail.com
Fri Oct 21 15:49:49 UTC 2005
> > I think maybe it's not the problem of the ARM, I have test cxxbasic on
my
> > at91rm9200's
> > board, it's ok. I rememer that if I generate binary file for c++, it
always
> > fails, but elf file is ok.
> What version of RTEMS are you using? What toolchain?
> Are you using the CSB337 BSP? Did you make any changes? I'm using the
CSB337 BSP.
I'm running 4.6.1 with CSB337 BSP from http://www.lopingdog.com/rtems/.
The toolchain is from www.rtems.com for 4.6.1.
Yanjun luo
