Getting C++ to work on ARM
Yanjun Luo
yanjun.luo at gmail.com
Fri Oct 21 15:55:21 UTC 2005
> > I think maybe it's not the problem of the ARM, I have test cxxbasic on
my
> > at91rm9200's
> > board, it's ok. I rememer that if I generate binary file for c++, it
always
> > fails, but elf file is ok.
> What version of RTEMS are you using? What toolchain?
> Are you using the CSB337 BSP? Did you make any changes? I'm using the
CSB337 BSP.
I just find that i'm using your BSP, and I had send two patch of this BSP to
you last year:-)
One for serial port driver and another one is ethernet driver.
Regards,
Yanjun Luo
