ampolish3
Ralf Corsepius ralf.corsepius at rtems.org
Mon Oct 24 20:15:49 UTC 2005
On Mon, 2005-10-24 at 16:45 +0200, Ralf Corsepius wrote:
> On Sat, 2005-10-22 at 19:54 -0700, Till Straumann wrote:
> > Some xx.am files (rtems 4.7) contain the
> > comment 'Automatically generated by ampolish3'
> > However, I'm unable to find that tool - any hints?
> Sorry for not having responded earlier, but I've been and still am busy
> with other topics.
> Right now, you won't find ampolish3 anywhere. It's my local perl-script
> I am using to generate most of the preinstall.am files inside of the
> 4.7-source tree.
> Given your request, I am considering an "emergency hack", i.e. adding
> the current immature script to the source-tree, where needed.
Meanwhile, as a temporary band-aid, I've added it to the tools/build/
subdirectory.
If you want to use it, you currently need to install it into $PATH and
to configure RTEMS with --enable-maintainer-mode.
Ralf
