MVME5500 board support status?
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Oct 27 20:11:31 UTC 2005
Peter Dufault wrote:
> On Oct 27, 2005, at 11:57 AM, Ralf Corsepius wrote:
>> You probably haven't applied the RTEMS patch to automake.
> I haven't, TOOL_VERSIONS says automake 1.9.6-0.
Being a -0 version doesn't mean it is patch free. Sometimes we know of
patches that are needed but have not been merged.
>>> autoconf 2.59-4
>>> autoheader 2.59-4
>>> autom4te-2.59-4
>>> automake 1.9.6-0
>>> aclocal 1.9.6-0
>>> RTEMS 4.6.99
>>> Binutils 2.16.1
>>> GCC 4.0.2
>>> newlib 1.13.0
>> Vanilla 1.13.0 won't work, as well as newlib-cvs currently doesn't  work
>> for some target (I am not sure about the powerpc).
>> => You also need the newlib RTEMS patches.
> I have that wrong, I left off the dashes.  What I'm using is:
> autoconf 2.59 with autoconf-2.59-quoting-20040817-1.diff which I hope
> is autoconf 2.59-4,
> automake 1.9.6 with no patches
> binutils 2.16.1 with binutils-2.16.1-rtems-20050816.diff (I hope
> binutils 2.16.1-3)
> newlib 1.13.0 with newlib-1.13.0-rtems-20050810.diff (I hope newlib
> 1.13.0-4)
> Is gcc 4.0.2 OK?
> Configure line is:
>  --target=powerpc-rtems \
>     --prefix=/opt/rtems-4.7 \
>     --enable-posix \
>     --enable-networking \
>     --enable-cxx \
>     --enable-rtems-debug \
>     --disable-itron \
>     --enable-maintainer-mode \
>     --with-cpu=7450 \
>     --enable-rtemsbsp=mvme5500
> Hmm, that 7450 looks suspicious, I better double check I had that  before.
> Peter
