MVME5500 board support status?
Peter Dufault
dufault at hda.com
Thu Oct 27 19:54:29 UTC 2005
On Oct 27, 2005, at 11:57 AM, Ralf Corsepius wrote:
> You probably haven't applied the RTEMS patch to automake.
I haven't, TOOL_VERSIONS says automake 1.9.6-0.
>> autoconf 2.59-4
>> autoheader 2.59-4
>> autom4te-2.59-4
>> automake 1.9.6-0
>> aclocal 1.9.6-0
>> RTEMS 4.6.99
>> Binutils 2.16.1
>> GCC 4.0.2
>> newlib 1.13.0
> Vanilla 1.13.0 won't work, as well as newlib-cvs currently doesn't
> work
> for some target (I am not sure about the powerpc).
> => You also need the newlib RTEMS patches.
I have that wrong, I left off the dashes. What I'm using is:
autoconf 2.59 with autoconf-2.59-quoting-20040817-1.diff which I hope
is autoconf 2.59-4,
automake 1.9.6 with no patches
binutils 2.16.1 with binutils-2.16.1-rtems-20050816.diff (I hope
binutils 2.16.1-3)
newlib 1.13.0 with newlib-1.13.0-rtems-20050810.diff (I hope newlib
1.13.0-4)
Is gcc 4.0.2 OK?
Configure line is:
--target=powerpc-rtems \
--prefix=/opt/rtems-4.7 \
--enable-posix \
--enable-networking \
--enable-cxx \
--enable-rtems-debug \
--disable-itron \
--enable-maintainer-mode \
--with-cpu=7450 \
--enable-rtemsbsp=mvme5500
Hmm, that 7450 looks suspicious, I better double check I had that
before.
Peter
