4.6.4a Anyone?
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Sep 9 11:30:39 UTC 2005
Hi,
I will have to throw myself on my sword on this one.  I made
a mistake and an going to have to cut a 4.6.4a.  As the release
approached, I was going through outstanding PRs and applying
those which were in 4.6 and clearly had fixes in the PR.
Unfortunately, I only tested on a subset of BSPs and none
used the file c/src/lib/libbsp/shared/console.c.  The patch I
applied from PR577 did not apply cleanly and I had to hand-edit
the results.  Obviously I screwed up.
Attached is the patch.
Does anyone else have any nits that need to be addressed?
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20050909/34ca61aa/attachment.ksh>
