PR469 IDE problem, was: Re: Any New 4.6.4 Issues
Thomas Doerfler (nt) Thomas.Doerfler at imd-systems.de
Fri Sep 16 08:08:59 UTC 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi,
Chris Johns schrieb:
> Ralf Corsepius wrote:
>> If his BSP was part of the official sources, we could even hard code
>> this into the configure script:
>> RTEMS_BSPOPTS_SET([SOMEOPTION],[angelopc386],[1])
>> RTEMS_BSPOPTS_SET([SOMEOPTION],[*],[0])
>> RTEMS_BSPOPTS_HELP([SOMEOPTION],
>> [Some explanation])
> This may not scale well. I have a PC on my desk where the Compact Flash
> is mapped as a slave on IDE1. Should we add a config for this and open
> the door to every PC configuration being a hard coded BSP ?
> Can the PC BSP be configured from the command line and then built from
> the command line or does it have to be invoked from the top level RTEMS
> configure call ?
I agree, I think having unique option sets in the BSP code will not be a
good idea.
Is it possible to put these things (as far as it makes sense) into a
custom file:
make/custom/pc386_with_secondary_ide_only.cfg
(well the name should be a bit better, but the method would make more
sense for me...)
wkr,
Thomas.
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
     http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.5 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDKn2ZwHyg4bDtfjQRAuryAJ9bfYWuCot8D3z9A2g/vBY4gFi5RwCfYpwK
mQ4BrsAQccY/wCF8h7u3YPE=
=jW9A
-----END PGP SIGNATURE-----
