PR649, was Re: PR469 IDE problem, was: Re: Any New 4.6.4 Issues
Thomas Doerfler (nt) Thomas.Doerfler at imd-systems.de
Tue Sep 20 04:19:46 UTC 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Chris,
> If that means while configuring RTEMS proper, that is the wrong place to do
> it.
> Joel has stated multiple times that the eventual goal is to provide RTEMS
> binaries that can be linked to applications, and it makes no sense at all to
> have multiple binaries that differ only in which ATA devices are expected to
> be present.
> The configuration should either be when the application is built, or at run
> time based on initialization parameters passed to the ATA driver.
Hm, so let me remind you, what is handled with this configuration: With
these configuration items you will specify, which IDE controller(s) are
present and used in the hardware you are using. Surely you can have very
similar PCs which differ only in the way the IDE channels are
equipped/used. But if you look at two PCs which differ in the harddisk
configuration, you may also find that they have different network
interface cards etc, in which case you will have to use (slightly)
different BSPs again.
Once again, if anybody has an autodetect solution for the IDE driver,
please feel free to implement it in the RTEMS driver. I personally have
no idea how it can be implemented, I have currently no time to
investigate on this matter and I am glad that the problems Angelo has
detected are solved.
wkr,
Thomas.
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
     http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.5 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDL43gwHyg4bDtfjQRAnqvAJ9GRAlBwLU1mAdVjitYuxXBY7UjagCcCTBV
uCsvVQPL++KndAgeMsuKSkk=
=1KDX
-----END PGP SIGNATURE-----
