Anyone tried TCP over loopback?
Phil Torre ptorre at zetron.com
Mon Sep 12 17:14:46 UTC 2005
On Mon, Sep 12, 2005 at 08:16:02AM -0500, Joel Sherrill <joel at OARcorp.com>
wrote:
> Phil Torre wrote:
> >OK, I found the problem.  The stack is just fine, it was a stupid app
> >error.  Thanks, Thomas.  :)
> There is a loopback sample test (testsuites/samples/loopback in CVS).
> Did you use it as an example?  If it is not right, it needs to be fixed.
I did not try the loopback sample.  I'm porting a SIP stack, and the
code that I'm working with had a bug (binding to the wrong address).
I'm sure the sample code is fine.
-Phil
Phil Torre                               phone: 425-820-6363 x234
Design Engineer                          email: ptorre at zetron.com
Switching Systems Group                    fax: 425-820-7031
Zetron, Inc.                               web: http://www.zetron.com
