Help! - Compilation error for mips-rtems tools under Cygwin
Bruce Robinson
brucer at pmccorp.com
Wed Sep 14 18:30:58 UTC 2005
Keith,
I have a set of scripts I used to build the MIPS tool chain under CYGWIN.
The GCC configuration looks like this:
/opt/gcc/gcc-3.4.1/configure \
--target=mips-rtems \
--prefix=/opt/mips-rtems \
--program-prefix=mips-rtems- \
--with-local-prefix=/opt/mips-rtems \
--enable-languages=c \
--with-gnu-as \
--with-gnu-ld \
--with-newlib
If you're interested, e-mail me and I can send you the complete set.
Do you mind me asking? Does tx_mips64 imply you're working with Toshiba
processors?
Bruce Robinson
At 11:15 AM 9/14/2005, you wrote:
>Keith Siders wrote:
>>Sorry for the long delay.
>>1. Yes, I did "make -k install" on binutils after
>>building it, so I assume everything went well. Got
>>lots of screen dump, nothing indicated failure of any
>>kind.
>>2. At first I did not have the path in cygwin.bat, but
>>I went back and put it in, restarted the shell, found
>>that all the normal *nix paths (/bin:/usr/bin: etc...)
>>still preceeded it. So I modified the user profile to
>>prepend any previous paths, got /gcc-mips-rtems/bin as
>>the first path, and it still made the same complaint.
>>$ echo $PATH
>>/gcc-mips-rtems/bin:/cygdrive/c/WINNT/system32:/cygdrive/c/WINNT:/cygdrive/c/WINNT/System32/Wbem:/cygdrive/c/Program
>>Files/doxygen/bin:/cygdrive/c/PROGRA~1/ATT/Graphviz/bin:/cygdrive/c/PROGRA~1/ATT/Graphviz/bin/tools:/cygdrive/c/Program
>>Files/cvsnt:.:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin
>>sidersk at siders-desk /source
>>I also see that I have '.' in the path, and I think
>>it's' coming from the DOS environment being passed in.
>>I've looked in various "old" DOS world .bat and .sys
>>files for the path info (I have more than shown here)
>>and I cannot seem to locate where this part of the
>>path is being set.
>>But since '.' is at the point /build/gcc/ or below,
>>should this be a problem?
>>Oh, and thanks to everyone for your help!
>Before you build, start a fresh shell and "echo $PATH".
>type mips-rtems4.7-gcc. Make sure they are what you think
>they should be.
>It is best to have a VERY clean environment when using Cygwin.
>You need to get rid of the Windows parts of the PATH as well
>as "." It is a security risk even if it isn't causing this.
>Also do an "env" command and make sure LIB, CC, and anything
>else that looks like it might be related to building software
>relates to Cygwin not Windows.
>--joel
>> - Keith
>>--- Ralf Corsepius <ralf.corsepius at rtems.org> wrote:
>>>On Wed, 2005-09-14 at 12:04 -0400,
>>>bndrobinson at cox.net wrote:
>>>>As to the error, I'd wonder if the MIPS assembler
>>>is actually being
>>>>used at the point where the error occurs. You
>>>should try getting the
>>>>compiler to list the tools that it is using.
>>>Did you read Joel's reply? Let me recap it in brief:
>>>The error you see indicates one or more of
>>>1. You missed to "make install" binutils
>>>2. You don't have the directory you installed your
>>>binutils into
>>>($prefix/bin) in your $PATH when building GCC.
>>>Ralf
>>__________________________________ Yahoo! Mail - PC Magazine Editors'
>>Choice 2005 http://mail.yahoo.com
>Joel Sherrill, Ph.D. Director of Research & Development
>joel at OARcorp.com On-Line Applications Research
>Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
