RTEMS Snapshot 4.6.99.2 and new RPMs
Karel Gardas
kgardas at objectsecurity.com
Wed Sep 14 19:08:51 UTC 2005
Hello,
till now I've been using CVS and tool-chain build from sources from
ftp.rtems.com/pub/rtems/SOURCES. Now, I would like to give a try to exact
recommended tool-chain, but I'm not able to find its location.
So where are all the sources for the packages below available? I'm
especially interested in RTEMS related patches, since I'm able to find out
location of upstream packages.
On Fri, 2 Sep 2005, Joel Sherrill <joel at OARcorp.com> wrote:
> - rtems-4.7-autoconf-rtems-2.59-4
> - rtems-4.7-automake-rtems-1.9.6-0
> - rtems-4.7-binutils-2.16.1-3
> - rtems-4.7-gcc4.0.1newlib1.13.0-4
> - rtems-4.7-gdb-6.3-1
Till now, I'm using:
autoconf-2.59-quoting-20040817-1.diff
autoconf-2.59.tar.bz2
automake-1.9.5-rtems-20050303.diff
automake-1.9.5.tar.bz2
binutils-2.16.1.tar.bz2
gcc-4.0.0-rtems-20050502.diff
gcc-4.0.0.tar.bz2
gdb-5.3-rtems-20040217.diff
gdb-5.3.tar.gz
newlib-1.13.0-rtems-20050512.diff
newlib-1.13.0.tar.gz
Thanks,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
