Help! - Compilation error for mips-rtems tools under Cygwin
Keith Siders
tx_mips64 at yahoo.com
Wed Sep 14 20:53:40 UTC 2005
--- "Joel Sherrill <joel at OARcorp.com>"
<joel.sherrill at OARcorp.com> wrote:
> Keith Siders wrote:
> > Ralf,
> > Can you be a bit more specific? Is this a tools
> > configuration issue, a build environment issue, or
> > something else altogether?
> The RPMs are VERY careful in the configure command
> they
> use. This is configure command generated by RPM for
> gcc 4.0.1 on mips-rtems4.7. It was from a GNU/Linux
> host.
> ../gcc-4.0.1/configure --prefix=/opt/rtems-4.7
> --bindir=/opt/rtems-4.7/bin
> --includedir=/opt/rtems-4.7/include
> --libdir=/opt/rtems-4.7/lib
> --mandir=/opt/rtems-4.7/man
> --infodir=/opt/rtems-4.7/info
> --build=i686-pc-linux-gnu
> --host=i686-pc-linux-gnu --target=mips-rtems4.7
> --with-gnu-as
> --with-gnu-ld --with-newlib --verbose
> --with-system-zlib --disable-nls
> --enable-version-specific-runtime-libs
> --enable-threads=rtems
> --enable-languages=c,c++
OK, that makes sense. Thanks!
- Keith
__________________________________
Yahoo! Mail - PC Magazine Editors' Choice 2005
http://mail.yahoo.com
