AW: MPC8XX Ethernet Speed
Wilfried Busalski w.busalski at lancier-monitoring.de
Wed Sep 21 06:56:57 UTC 2005
Hi Steven
I'am using a MPC565 with a cs8900 Chip and if i ping my system i get the
following answer
Antwort von 172.16.1.10: Bytes=32000 Zeit=84ms TTL=255
Antwort von 172.16.1.10: Bytes=32000 Zeit=85ms TTL=255
greetings
Wilfried Busalski
-----Ursprüngliche Nachricht-----
Von: Steven Johnson [mailto:sjohnson at sakuraindustries.com]
Gesendet: Mittwoch, 21. September 2005 07:12
An: rtems-users at rtems.com
Betreff: MPC8XX Ethernet Speed
Hi,
We use a heavily customized MPC8XX BSP to suit our strange hardware.  We
have a 100Mhz MPC862.  Rtems works fine, has done for years.  Ethernet
is just being implemented now.  We are using the FEC of the MPC8XX and
the main processor is running as 100Mhz.
Now my Engineer is telling me if he opens a socket to the target, and
just echo's the data back, he is only able to sustain around 33KB/s
transfer rate.  This seems pretty dodgy, for 100Mbps Ethernet running on
the FEC.
My question is, what sort of speeds do people experience with MPC8XX
type hardware and FEC's in their designs with Rtems?  I dont need any
benchmarks or the like, just what you have experienced.
Thanks,
Steven Johnson
