building bsp w/o examples
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Fri Sep 23 13:29:07 UTC 2005
stanley jobson wrote:
> On Fri, 23 Sep 2005 09:35:25 +0200
> Ralf Corsepius <ralf.corsepius at rtems.org> wrote:
>>On Fri, 2005-09-23 at 08:33 +0200, stanley jobson wrote:
>>>hi,
>>>is there an option to build an bsp image w/o examples (e.g. ppp) ?
>>This is not supported in rtems-4.6, in rtems-4.7
>>configure --disable-tests should do what you want.
> interesting ...
> will this include something like: libnetworking/* (e.g. pppd, webserver,
> telnetd ...)
> when doing objdump -d image i see a lot of ppp functions which i really
> do not need ... but bloats my image :(
How are you linking the application? It looks like something is wrong
there. RTEMS is a big library and carefully constructed so you do not
link in functionality you do not reference directly or by implication.
I saw a "LD" in a previous email. Are you using the GNU tools provided
with 4.6 or some other toolset?
How are you linking? It appears to be wrong.
> thx
> regards,
> stan
joel at OARcorp.com On-Line Applications Research
